We can only theorize based on how other EREVs work - but yes, when the battery reaches the point at which the generator is utilized to keep the battery from dropping any further and charges it - if you are using more power than the generator can provide and the battery loses charge, you may end up going into a limp mode where your power is limited.
So then the Harvester option isn't an option for when you're moving at say highway speed. Unless it can charge the batteries faster than they are being used, it would only be good when stopped or at very low speeds. Do I understand that correctly?
Scooby24
Olathe, KS
'21 MME-GT Star White; '22 MME Prem AWD DGM
It all depends on how they plan on sizing the engine/generator combo. I would assume they are targeting it to be able to provide enough power to drive at highway speeds without too much trouble but we have to see.
It's a voyage of discovery lol
A line to get gas? Where do you live, the 70s? :angel:
Buc-ee's have lines at gas pumps because they have this odd cult following, and all the knuckle dragging gas pump parkers who leave their vehicle to get their super sized sweet teas, 2 pound BBQ sandwiches, Beaver Nuggets, and XXXXL Beaver shirts.
They have a unique charm and I occasionally get gas at one, only at 2 am on random Tuesday nights when it isn't a circus.
DaveGunter
Maine
'21 MME Select AWD comfort/tech, '22 Ioinq5 SEL
CT, Lightning, R1T, Silverado EV, are all right at 2mi/kWh at 60-70 mph, add a trailer of any size and it goes down to 1 mi/kWh, up an extended grade an it goes down to 0.5 mi/kWh, so a generator needs to be 60kW just to keep up under normal towing mode 120kW under extreme demand add in 10% AC to DC loss and you’re right at 130 kW which is what Ram is saying for the Ramcharger.
mcnels1
Kia EV6, BWM i3 rex, Honda Ridgeline
I read that BMW reduced the size of the range extender fuel tank on the i3 in the US (vs Europe) because if the gas range exceeds the all electric range, it gets reclassified as a PHEV. I don't have a source, so take with a grain of salt
Close. They limited its effective size in software, meaning there was still 1/2 gal. of fuel in the tank when it when the car said it was empty. Source: I own an i3, which I've coded to make the entire fuel tank usable, which is still only 2.4 gal.
DrumReaper
Fred
SC
maverick
Everyone seems to think diesel is out of the question. Poor environmental P.R. Especially for VW.
Doesn’t have to be sourced from VW… I’m sure caterpillar would love the contract.
395N
Orange County CA
22 Jeep Rubicon XR
It disrupts the normal traffic flow at the station. Y'all ain't ever been to a Bucee's apparently. People lined up waiting to fill up next when along comes one of you folks that disrupts the normal flow.
I don't see the problem in Scout moving the filler door and the associated line. They want to claim to be an American company resurrecting an American brand. Then they go ahead and do something goofy like this.
Name checks out.
ToadB
Too many to list
2.8L Cummins? Might be a bit bulky.
Maybe International will come back and decide to build the generator since navistar rebranded back to International. The return of the IHC Comanche?
RC616
tesla MS PLAID
Not by me, but good analysis and some predictions about the Scout Harvester EREV gas range extender system -- talks about 3 cylinder gasoline engine, HP output, EV battery pack size, fuel tank location, and even approach / departure angle.
Have a watch and share what you agree or disagree with...
Unable to open video for some reason. Wonder if there would be consideration to a diesel powered generator for more efficiency? Uncertain if that is even possible or safe! Not my area of expertise for sure but would potentially allow further mileage before filling up.
Scooby24
Olathe, KS
It would be wild if they were to put in a diesel. With the nature of diesel fuel going bad easily, the need for exhaust fluid, DPF cycling, maintenance needs for emissions, etc...I would NOT want one.
