Towing Range with Scout - Harvester EREV vs. Full-EV and Traveler vs. Terra
'22 Model X
Quoted range is 350 miles for the full-EV and 500 miles for the Harvester EREV, so what are we estimating would be the towing range in terms of % reduction per 1,000 lbs let's say? Also, do we think there will be a towing range between the Traveler and Terra?
Hoping our Rivian owners who've towed with the R1S / R1T can chime in on this one.
jhscout
Jared
Shawnee, KS
Ford Expedition, Tesla MYP
I have towed occasionally with my Tesla MYP. It just over doubled the watts/mile. Normal usage is 290-310watts/mile and when I was towing, about 620-650w/m. This is concurrent with power usage reports from all of my EV owning friends as well as magazine testing. I was towing a 3000lbs ski boat.
Based on Rivian and Lightning reports the impact on range is is more due to aero than weight. Since it doesn’t appear Scout is going for an overly dramatic aerodynamic shape (Lucid style), I’m wondering if aero will be less of a concern here. Plus, in order to reach 350 miles of range in a platform this upright it’s going to have to have about a 150kwh battery.
Jrgunn5150
J.R.
Ionia Mi
A bunch
Based on my experiences towing open car trailers with a Lightning, I'd expect 100-125 miles of loaded towing EV only range.
ocnsvl
Ken
upstate sc
Ram1500, Mini Cooper S
Trailer aero will play a significant role in power consumption. Towing an open car trailer cuts mileage on my ICE truck by 15-20%. When towing our enclosed trailer it is a 40-50% drop. Folks I've talked to that are towing with Rivian or Lightning are seeing a range of 80-125 miles.
ToadB
Too many to list
The drop is 80-125 or they only get 80-125 while towing?
Austin, TX
2018 GMC Sierra 1500 6.2L All Terrain 4x4 (Black)
Lightning here as well, 8k lb, 32ft travel trailer, averaging between .7 and .9 m/kWh when towing... netting ~ 100 miles of range.
astricklin
Andrew
Which is roughly half the normal efficiency/range, correct?
astricklin
Andrew
As has been said, this is going to be highly dependent on the individual trailer.
However, I would expect roughly the same percentage drop as you see in an ice vehicle of the same dimensions.
So if you're towing with a full-size SUV or half ton pickup, then figure out what percentage decrease you have now and assume you'll have that same percentage decrease.
Or just assume worst case scenario of half and be surprised if you get better.
A huge key will be SLOWING DOWN. If you're used to driving 75+ mph towing a trailer, slow down below 70 (heck even below 65) and you'll see a significant increase in efficiency.
Austin, TX
EPA is around 2.4 mi/kWh, I rarely see better than 2 in daily driving (TX highways are 75+ and AC is always running). So Just under half for towing.
I should add, my numbers include slowing down to 65 max when towing, because while the lightning is an EXCELLENT tow vehicle, anything over that gets dicey when you hit side winds, rough roads, etc so it's more of a safety thing.
Foobar
New York
'23 Rivian R1T, '19 Tesla Model 3P, '22 Energica Eva Ribelle
I have been towing a NuCamp TAB400 and an Airstream Trade Wind 25FBT with my Rivian R1T. It is true - weight doesn’t matter much. Both trailers ended up around 1.1-1.2 miles per kWh even though the Airstream is twice as heavy. On my large battery / quad motor config, that comes out to around 150 miles of range on a full charge. I usually drive for a couple of hours then charge for half an hour. Rinse repeat.
Pretty much every ICe vehicle and every EV it seems now gets about 50% range when towing—give or take some depending on the trailer. That’s what I get with my Defender. About a 50% hit. Most of the Rivian reports are somewhere around that. The Harvester will probably be similar and maybe get 250 range if starting with a full battery, but I’m guessing less than that since tow mode will need to kick in earlier in the battery cycle—same way they do it on the Ram Charger. So maybe 200. That’s better than the 175 the BEV will likely get, and with faster refueling, but not much of a difference in range really. And the Harvester is likely to get pretty crappy mileage when towing compared with similar ICE vehicle. All in all, I think I prefer the Charger BEV as a tow vehicle.
TreeKiller
Scottsdale, AZ
17 MB C300 Coupe, 17 Jeep WK2 Hemi Trailhawk, 93 Jeep YJ, 2027 Scout Traveler
Following this thread for sure. I plan to daily a Traveler Harvester and tow my old Wrangler behind it on weekends. Trailer and Wrangler are about 5,200 lbs and of course the Wrangler already has the aerodynamics of a brick. A ~250 mile range when towing, plus the ability to continue charging on gas while the Traveler is parked and I'm out wheeling my Wrangler would work just fine. My Grand Cherokee Hemi Trailhawk gets 8-11mpg on average when I'm towing, depending on if I'm towing hills or flats, so that's 200-275 mile range, and that has worked just fine for me.
