A lot has been said about the interview-including that all the numbers are still subject to change. Personally I think the 5k limit was due to the Harvester being designed for max range when not towing. But that is a compromise that probably can easily be adjusted (but then the real question is should it be adjusted). Most people don't tow much if at all. Any significant reduction of total range could easily be more harmful to most people than a increase in maximum load while towing. Not to mention, significant is a very subjective term. Is 50miles significant, 100 miles?
Chavannigans
2004 GX470, 2020 Honda Odyssey, 2024 Husqvarna Norden 901
Reduced payload from extra Harvester weight = Reduced towing capacity
The rear axle is only rated for so much weight
Not range related.
Pogeegitz
2022 Ford Maverick XLT 2.0L
Would like to tow our new Tahoe 1950, 4600 lbs empty. Was planning on towing with a Terra w/Harvester, but the numbers aren't looking great (still holding out hope). Most of the towing would be less than 50 miles - can get to dozens of lakes and rivers in our area, and use the Expedition for longer boat trips. A few times a year, will make longer trips to the hunting shack with a 4-wheeler trailer.
