Monti
Minn
07 all-wheel drive equinox drive equinox matter of fact you should giv
2024-25 is Building the shops. Start of 2026 is tooling the factory. around q1 of 2027 is start of production is what the rumor around it has been.
It shouldn't take them that long once the buildings in closed
Well in Scouts holiday video if you saw it he’s says that production will start late 2026 But you always want to be safe and make sure its not half assed. Scott(CEO) said that tools will begin starting 2025 and training will start. And production should start sometime in 2026 or 2027 depending on timing.
Once building is under roof and all manufacturing equipment is onsite. Riggers will start laying out equipment placement any electric and plumbing will be check for proper placement. Along with over head lighting and automation HVAC paint exhaust so once under roof your looking at 8 to 10 months before assembly line is done and then your stocking actual vehicle parts and batteries etc. and that's with no hiccups so 2027 is realistically achievable timeframe. Keep in mind they probably have quite a bit of underground stuff needed to be done and the electric power needed to run this building im sure its a task in itself as to getting it to the building.
