Power output options
Phil
Phil
Granger, Indiana
2000 Xterra; 2012 Prius C
I would love to have a 120V/30amp power outlet so I can plug in my travel trailer!
They have said there will be outlets but the amperage is not confirmed. I would suspect the 120 v outlets will be 20 amp for widest compatibility. My travel trailer runs fine on 20 amp as long as I don't try to run either the AC or electric heater along with any other big draws.
The Terra is supposed to get a 240v outlet and it will almost certainly be 30 or 40 amp.
If you get the Terra you could use an adapter to get the single leg 120v 30 amp outlet you want from the 240.
