Need 37” Tire wheel combo available on the traveler model at launch💪💪
socal.2fast
so.Cal.
bronco
Definitely need the 37” option on the Traveler at launch. The new 4 door bronco looks so much better on 37”s and with the traveler being a little bit bigger I think it will fit the vehicle much better. look much more rugged.
No_Remorse
Courtney
While it may look better, the axles, bearings, brakes and other components need to be able to handle moving that extra weight around. In other words they need to build it from the factory with those specs in mind vs. putting them on as an after-thought.
Has anyone tried changing a 37 in the field, heck even at home home? I thought my 35's were heavy but man those 37's are heavy AF.
Given that the Terra has already published them as an option - I would bet the drive train can handle it. Real question is if the clearances are different between the two.
That said, at some point we probably should stop supersizing everything. Our JLURD came with 33's. Since we already had 35's on our JLUR, we just switched them out. They ran a lot better on the diesel. That said, the Traveler will have even more torque.
WXman
Central Kentucky
2025 F-150 Lightning Flash, 2025 Jeep Wrangler Unlimited Rubicon
Enjoy your 120 miles of range.
Yeah, I do think it's odd to build EVs and then saddle them with equipment that is counterproductive. I'm an off-road guy. Heck, today I drove my Rubicon to work. But I'm also practical. A 37" tire wrapped around an 18x9" wheel with tire weights, TPMS sensor, etc. is going to tip the scales at around 115 lbs. Why do people want that on production vehicles that are already trying to extend range with ICE engines attached?
